Intermittently Noisy transfer case
Old Oct 17, 2008 | 10:52 PM
3pedal's Avatar
3pedal
Default Intermittently Noisy transfer case
The transfer case in my Dak has started to nake some serious noise. It is a nice screeching sound, and people standing on sidewalks look at me as I go by. The fun part is, it does not do it all the time. It will for a drive or two, and then half way home it will stop. I think it may be tied to outside temp a little, but an not sure.
I am supposed to take a road trip in the truck in 2 weeks. The noise will drive me nuts, but even worse would be having it break in Northern New Mexico.
Any thoughts? It just rolled 100,000 miles today. I had it rebuilt at about 50,000 when I bought the truck. I would hope these aren't 50,000 mile units.
The details:
1999 Dakota
Extended Cab
318
4x4
5 speed
3.73 gears
Stock tire size
Old Oct 18, 2008 | 01:11 PM
dakotaguy's Avatar
dakotaguy
Default Clutch area?
Are you sure it's not the throw out bearing? Mine used to do that in cold weather.
Old Oct 18, 2008 | 02:40 PM
f0x672's Avatar
f0x672
if i were you dude, i would be under that thing already looking at the fluid levels in both the trans and transfer case, and i highly doubt its a throw out bearing dakotaguy, he'd most likely have shifting issues.
Old Oct 18, 2008 | 07:58 PM
3pedal's Avatar
3pedal
The fluid level is fine. The little that escaped even looked fine.
When the noise is happening, it is completely dependent on truck speed, if I put the clutch in the sound stays. If I stop, put the T-Case in neutral, and run through the gears, there is no noise.
This is really strange.
Old Oct 19, 2008 | 05:29 PM
3pedal's Avatar
3pedal
It is funny, it is warmer (60s - 70s) this weekend, and the t-case is quite. When it was in the 30s - 40s, it was making a racket. I still have problems thinking is it temp related, because it does not go away after driving a while. Surley the T-Case warms up with some miles.
Old Oct 19, 2008 | 06:17 PM
extreme93's Avatar
extreme93
Does this sound anything like the problem you're experiencing.
http://www.jeepforum.com/forum/showthread.php?t=509776
Old Oct 19, 2008 | 06:23 PM
extreme93's Avatar
extreme93
or this might help:
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
Old Oct 19, 2008 | 09:42 PM
TheePlaymaker's Avatar
TheePlaymaker
you have the right fluid in it? i know its a stupid question but ya never know it takes atf+4
