from a 6 lug to a 5
Old Nov 17, 2008 | 01:00 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
Default from a 6 lug to a 5
i got to thinking that it would be cool have a 5 lug on my truck and was wondering if it would be much of a hassel to swap over from the 2nd generation 6 lug eaither the 1st or 3rd generation.....i know it wount be a bolt in swap...but could it done in a weekend?
how much would aftermarket swaps be?
how much in general would it take to do this swap$$$$$
and how much labor to do it?
and im sure that it would need an alignment afterwards
Old Nov 17, 2008 | 01:15 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Just an FYI, the 1st gens have the same bolt pattern as the 2nd gens...
Crazy4x4RT's Avatar
Crazy4x4RT
Accually it can be a simple bolt in swap. Use wheel spacers there alot to choose from. Some can change your wheel bolt pattern. Check these sites out. We have this listed on 1st gen FAQ. The only bad thing is it may stick your tires out a little bit. But you can also offset your wheel backspace to get a stock look.
1987 - 1990 5 x 4.5" (lots use this bolt patter from chevys to toyota)
1991 - 2004 6 x 4.5", 6 x 114.3 (rare hard to find)
Like said above most 1st gens share the same 6 lug
Wheel spacers
http://www.spidertrax.com/s.nl/sc.7/category.2856/.f
http://cgi.ebay.com/ebaymotors/Wheel-Adapters-6-Lug-4-5-To-6-Lug-5-5-Spacers-1_W0QQitemZ270260469385QQihZ017QQcategoryZ42614QQr dZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q 2em118Q2el1247 (search what this seller is offering)
Check ebay lots to choose. Some to convert bolt pattern size too.
Old Nov 17, 2008 | 03:00 PM
batman13's Avatar
batman13
dude on another forum i frequent just put corvette lugs and rims on his, not super cheap or easy to do since there is a bit of fabrication needed to get everything to fit, and be safe
Old Nov 17, 2008 | 10:56 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
yea...spacers make the most since.....but ill have to make sure the rims i get are offset to counter the spacer width
Old Nov 17, 2008 | 10:58 PM
varsis's Avatar
varsis
get like half to 1" spacers it might look cool with a bit wider stance...
Old Nov 17, 2008 | 11:06 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
yea...i want some Ram rims...but idk what theyd look like
give me a few and ill shop some on
Old Nov 17, 2008 | 11:07 PM
rtdakota2001's Avatar
rtdakota2001
int there some kind of regular maintenance with spacers? like monthly torque check on the lugs and whatnot?
Old Nov 17, 2008 | 11:08 PM
rtdakota2001
sooooooooo.............what ya gonna be doin with those 20"s?
