v8 throttle body swap
Old Mar 27, 2012 | 01:26 PM
moe7404's Avatar
moe7404
my trouble is i cant do work like that. i have i find someone to that kind of work for me. my regular shop wont do high performance work.
Old Apr 2, 2012 | 11:15 AM
mgaither0's Avatar
mgaither0
all I need for the swap is the throttle body, a new gasket and the cable rite? This would be better then doing like a throttle body spacer? I know alot of people dont like them. I though the v6 and v8 had the same size throttle body?
Old Oct 13, 2013 | 01:14 PM
Pez18's Avatar
Pez18
What kind of difference would it make if I put a newer TB (say a 3rd gen dakota v8) on my 95 V6? Would it bolt on still regardless of the big age gap?
Old Oct 13, 2013 | 03:11 PM
Blacknights's Avatar
Blacknights
The 3rd generation never had an engine like yours. 05+ model years share nothing with a 95 engine, our TB is even a single not a double valve.
Old Oct 14, 2013 | 11:36 AM
Pez18's Avatar
Pez18
So the 5.2 magnum was last put in the 2000 kotas right? So one from the 2nd gen would work? Just need to replace the throttle cable as well. How about the 5.9 tb? Is there any major difference between the two?
Old Oct 14, 2013 | 12:27 PM
Blacknights
If I remember correctly only 3.9, 5.2 and 5.9 throttle bodies can be switched out. Can someone verify that there 1st gens can use 2nd gens, idk know of anything different or special about the two gens and tb differences?
Old Oct 14, 2013 | 03:15 PM
magnethead's Avatar
magnethead
I believe you are correct- Holley manufactured the castings for all of the 3.9/5.2/5.9 TB's for the same manifold bolt pattern.
Old Oct 14, 2013 | 09:31 PM
Pez18's Avatar
Pez18
The only difference I've seen is the connectors for the throttle cable, but I thought I heard somewhere that a tb from a newer vehicle would make a greater difference than a switch within the same generation
Old Oct 14, 2013 | 10:26 PM
magnethead's Avatar
magnethead
no, the castings were the same that I know of. Yes, the connectors changed here and there, but the castings were the same.
Old Oct 15, 2013 | 12:10 AM
Pez18's Avatar
Pez18
Would I be able to swap out the connectors between the 2? Or is the new cable the best choice?
