Engine just Dies
Old Dec 8, 2008 | 12:12 PM
Captain Obvious's Avatar
Captain Obvious
Default Engine just Dies
Hello I have a 2004 Dodge Dakota with the V8. Having problems with the engine shuting off with out warning. It seems like the fuel pump shuts off. I took it to the dealer and they said there was weak fuel preasure. They replaced the fuel pump. After I got it back about a week later still having the same problem. There is no check engine light on. And it dosent happen all the time. It runs great when it does. And everytime I try to take it back to the dealer it runs fine. It has left me stranded about 6 times now and when it shuts down it wont restart from 5 min to letting it sit overnight. Has anybody expeirenced something like this? Any suggestions would be greatly appreciated. Thanks in advance.
Old Dec 8, 2008 | 12:14 PM
varsis's Avatar
varsis
I would try replacing the relay. Next would be explain how it does, is it straight dead? Or is it just sputter for a bit than die?
If it just flat out dies I would suspect Crank or Cam Sensor. Maybe even your alternator is starting to go bad.
Old Dec 8, 2008 | 12:24 PM
Captain Obvious
Its just straight dead. But the battery still has plenty of juice. It still cranks it just dosent fire. We sprayed starting fluid in the intake and it started to sputter which would lead me to beleive its not getting any fuel. Where would the relay be located.
Old Dec 8, 2008 | 12:29 PM
matj1990's Avatar
matj1990
vapor lock ??? umm also could be somthing in your fuel tank getting sucked into the line then returning after sitting ? hard to say had this typ of thing happen when i turned a boat gas can into a tank for a off road truck
Old Dec 8, 2008 | 12:40 PM
varsis's Avatar
varsis
hmmm, thats very odd... Sounds like the injectors aren't spitting juice. Inaways I would hook up a pressure tester, run the truck until it dies. watch the gauge the whole time, only way you will know if it's something before the injectors. I think some sensor is failing, and believe some electronic stuff can do really weird crap.
Old Dec 8, 2008 | 12:45 PM
Captain Obvious
The only problem is it dosent happen all the time. Sometimes its once or twice a week and sometimes its maybe once a month. I will try replacing some of the relays and hopefully that helps. Thanks for the advice.
Old Dec 8, 2008 | 12:48 PM
varsis's Avatar
varsis
well, here is something that happened to me once, a bad coil, i would be driving along minding my own business out of no where it would die.
So I would try to start it no luck okay, wait a bit 5 minutes and it would start up again. Believe me electronic stuff can be intermittent...
Old Dec 8, 2008 | 01:42 PM
wink2873's Avatar
wink2873
is it showing any codes? try the key on/off/on/off/on trick and see if any codes come up next time that happens.
Old Dec 8, 2008 | 02:38 PM
rtdakota2001's Avatar
rtdakota2001
did you OHM your injectors? check that.
Old Dec 8, 2008 | 03:06 PM
Captain Obvious
What does this mean?
