4cyl dakota problem
Old Dec 11, 2008 | 04:23 PM
coreed's Avatar
coreed
Default 4cyl dakota problem
my dakota backfires if your givin it alot of gas before shifting to the next gear. its got alooooooooot of miles. 250k on original engine. if you give it more than half throttle it will backfire but below half throttle it wont. can anyone help me?
Old Dec 11, 2008 | 04:26 PM
Spidamantnmc's Avatar
Spidamantnmc
is there a custom exhaust?
Old Dec 11, 2008 | 04:27 PM
coreed's Avatar
coreed
nope completly stock.
Old Dec 11, 2008 | 05:09 PM
rtdakota2001's Avatar
rtdakota2001
maybe the cats are clogged up? wait for batman, i think hes the only 4 cyl guy around.
Old Dec 11, 2008 | 05:10 PM
rpowell's Avatar
rpowell
Is it backfiring through the carb/TB or the exhaust? Don't know if it will matter, but usually my mechanic says that if pops back through the carb then it is the valves, although we only work on motorcycles, so it may be different. Hope somebody comes up with some ideas for you.
Old Dec 11, 2008 | 05:27 PM
batman13's Avatar
batman13
do you let off the gas before you shift?
if the pedal gives you a slight kick, means its coming out of the TB so your valves need adjusted,
if not, its coming out of the exaust. not sure what causes it really, mine does it, louder now with the bigbore TB. its extra fuel that dosnt have a chance to burn in the cylinders so it burns on the way out,
my bet would be...... well, honestly im not sure, i've done just about everything to this truck except timing and its still there. i dont mind it, (maybe im just too abusive.)
could be worn out valve springs at 250k i wouldnt be surprised, mines got 115k but its had a rough life.
Old Dec 13, 2008 | 09:15 AM
coreed's Avatar
coreed
it back fires thru the throttle body. the engine runs great! no smoke/ taping/ leaking oil or anything. my mpg hasent changed any ether, about 400 mile to a tank, it cost me 25$ to fill all the way up so im not complaning! it doesnt bother me that it does that cause i rarly go over half throttle in it, i would like to figure out what is wrong with it but im not going to touch it till something breaks. it will probley have 300k or more till that happens. when it does i got a 318 with a 5spd waiting for her. all i need is a wireing harness from a 1500 series that is similar to my truck.
Old Dec 13, 2008 | 09:43 AM
batman13's Avatar
batman13
how the hell do you not go over half throttle?
takes me like 5 minutes to get to 60 wide open.
the only problem i have is an exuast leak at the mani.
Old Dec 13, 2008 | 10:01 AM
coreed's Avatar
coreed
yes it is slow, very very slow! but im not in any rush to go anywhere. i want my truck to last. thats why i got a jeep to beat on
Old Dec 13, 2008 | 12:00 PM
batman13's Avatar
batman13
im not in a rush...
but i want to merge at speed so it easier...
oh, rtdakota....
the 2.5's only have 1 cat
