Rear sway bar?
Old Dec 17, 2008 | 05:22 PM
greenweenie's Avatar
greenweenie
Default Rear sway bar?
My rear sway bar has plastic dog bone type links that connect the ends of the sway bar to the chassis. Is this a stock or aftermarket sway bar? I was looking in the service manual and it shows a pic of something that looks like it's all metal.
I need to know because it looks like either the bushings are worn or the hardware is coming loose.
Old Dec 17, 2008 | 06:30 PM
varsis's Avatar
varsis
take a pic.
Old Dec 18, 2008 | 11:36 AM
TheePlaymaker's Avatar
TheePlaymaker
its stock im pretty sure because mines like that too
Old Dec 18, 2008 | 11:44 AM
rpowell's Avatar
rpowell
They make adjustable ones & disconnects so you can remove them while off-roading for more articulation in the rear for Jeep, but I think a set would probably fit our trucks. You can also adjust these out to make the suspension a little stiffer if you want. I have a Jeep Outfitter 1/2 block from my shop, so I am going to pull one mine off and go match it up. I'll let you know what I find.
Oh yeah, yes it's stock.
Old Dec 18, 2008 | 11:49 AM
00DakR/T's Avatar
00DakR/T
Yeah, I had to replace the rear sway bar links on my truck too. Not a bad job and the parts were only about $40 for both of them.
Old Dec 18, 2008 | 02:07 PM
JBs DAK's Avatar
JBs DAK
Yep,those are stock. Crappy, but stock.
Easy to replace & odds are, u need to replace them.
I say that cause,.. They are crappy at best, What a
poor design. 40 bucks from Advance auto.
Old Dec 18, 2008 | 02:30 PM
bpark8824's Avatar
bpark8824
Yup i just replaced mine on the 3.9 and it was $40 from Napa. Easy fix only took 10 minutes.
