Headlight issue?
Old Dec 22, 2008 | 04:09 PM
2004 SLT 4X4 Dakota's Avatar
2004 SLT 4X4 Dakota
Question Headlight issue?
I have a question? Can anyone help me with solve an electrical problem on my 1997 dodge dakota with the 3.9L engine. I replaced the headlight switch because it was defective & everything was working just fine for two weeks. Now for some reason, all of the lights are not fonctioning so what should i be looking at? Does any body have any proper wiring diagrams for this truck as well as values to use when checking the switches and relays?
Old Dec 22, 2008 | 09:07 PM
01SilverCC's Avatar
01SilverCC
A Haynes book for your truck should have diagram and instructions on testing the multi-function switch for the proper continuity. Test it with a digital volt meter. I would say start there. It's also possible your new headlight switch could be defective too. But I wouldn't think that to be very likely.
Jimmy
Old Dec 22, 2008 | 09:12 PM
Billiam's Avatar
Billiam
Don't forget your fuses. Check the connections to your switch, you may have not seeded it on there all the way.
