HEADLIGHTS for sale!!!!!!!!!!!!!!!!
I know hey. About 100ft light output on each side. I want to do that retro to my sierra, just buy the aftermarket denali lights, pop them open, and shove some tsx's in there or the ls430. The tsx's give you more of a likght flicker, going from blue to purple to hyper white, while the ls430's are just for pure light output. Takes about 3 hours to do a retro. You already have the projectors mounted in, just take the old ones out, and put in some new ones.
second bold - i want to get them set back a bit (mounted closer to the fender)...and then ill think about poppin in the new projectors.....
i was wanting to do this with my two piece set and have a crystal clear turn signal housing that i paint flat black on the inside...or white(since im doin a "white out" project)
First bold: The light flicker that you see is when your vehicle is lower then the beam cut off from the projector. Have you ever been driving at or infront of a car with HID's and see the light change color, thats what the flicker is. TSX's are known for the beautiful color flicker. Basically at the cutoff ____/----- at the top part is where the flicker is usually its either hyper white, blue or purple.
And as for the headlights you want, I have those ones. They are a one piece, and there is only one spot for the turn signal bulb, but our trucks have 2, so you'd have to put a resistor on one bulb to trick the computer into thinking that there is one there. Pretty much with those ones, it eliminates the turn signal housing.
i want a set of CRYSTAL CLEAR HEADLIGH ASLEMBLYS(headligh and turnsignal) like these
and take apart the healight adn fit a projector inside to look like this
AND still have the lower section for the turn signal bulbs...and take then apart and paint the inside either flat black or white
i thought you couldnt switch from high to low on an HID kit??? why would i need that solenoid?
what if i just get either one of the projectors you listed above and just install a HID kit and go from that?
oh yea b4 i forget!! i wanna see your truck in daylight!!!
