Knock sound from rear of engine
Old Jan 7, 2009 | 01:14 AM
tj_110's Avatar
tj_110
Default Knock sound from rear of engine
Hi, new to this and I couldn't find any threads on this. The knock is a low muffled sound coming from around the back of engine. It's a v-6 gasoline auto trans. I checked under and nothing is loose. Any suggestion before I pay lots of money to a shop for this. thanks
Old Jan 7, 2009 | 01:17 AM
Spidamantnmc's Avatar
Spidamantnmc
check for a hole in ur muffler
Old Jan 7, 2009 | 01:33 AM
tj_110's Avatar
tj_110
its coming from the engine or trans area. the muffler does have a drain hole in it, but no other hole
Old Jan 7, 2009 | 11:45 AM
matj1990's Avatar
matj1990
drain hole in the muffler???
Old Jan 7, 2009 | 12:23 PM
dodgerules86's Avatar
dodgerules86
You've never heard/seen of a drain hole in the muffler? You might wanna go look at them at the parts store.
Old Jan 7, 2009 | 01:07 PM
matj1990's Avatar
matj1990
i would think a drain hole in the muffler would be bad ? air leak causing that sound i have seen alot of mufflers never seen one with a hole in it that had a purpose
Old Jan 7, 2009 | 01:12 PM
dodgerules86
No, they have holes in the muffler to let water out, so it causes less of a rust problem for it.
Old Jan 7, 2009 | 01:19 PM
matj1990's Avatar
matj1990
i understand that but any hole in the muffler would be a leak i no there is some companys that do that but i no my stock muffler never had a hole in it
Old Jan 7, 2009 | 01:37 PM
dodgerules86
I'm sure he knows the difference between a drain hole and a legitimate hole, since he specified it was a drain hole.
tj_110, you might want to try to figure out where the sound is coming from. you said back of the engine or maybe transmission area. Can you crawl around and try to figure out which one?
Old Jan 7, 2009 | 01:43 PM
matj1990's Avatar
matj1990
i did not say he didnt no the difference but i dont recall dakotas having a drain hole in the mufflers ? only thing iv ever seen with a drain hole in the exhuast was a vehicle with stacks or a atv and bikes
