are magnum heads different?
Old Jan 12, 2009 | 02:17 PM
dmcpher's Avatar
dmcpher
Default are magnum heads different?
i have a 1998 dodge 1500 4x4 with 5.9 magnum... does anyone know if the magnum heads are different then standard heads?
Old Jan 12, 2009 | 03:33 PM
varsis's Avatar
varsis
yes they are different i think mostly on some feeding the oil, but they are different.
check out this article:
http://www.hotrod.com/techarticles/e...ine/index.html
Old Jan 12, 2009 | 03:45 PM
wink2873's Avatar
wink2873
yes they are different than the pre-magnum LA engines (3.9, 5.2,5.9) however, all LA engines were converted to magnum in 1992. so any 5.9 from 1992+ will have the same heads. they are basically a different bolt pattern, and higher flowing.
Old Jan 12, 2009 | 06:55 PM
rtdakota2001's Avatar
rtdakota2001
the oiling system is different, i believe there is a company out there that makes them compatible with LA blocks, but dont quote me on that. the sweet thing about an LA is that you can put a blower on those heads, i dont mean a supercharger, i mean the wicked looking blower part coming out of the hood.
Old Jan 12, 2009 | 07:40 PM
f0x672's Avatar
f0x672
and the magnum cylinder heads have additional valve cover bolts versus the 5 bolts on the LA heads. helps with the leaking issue they once had, so ive read.
