Transmission trouble. need my truck help!
Old Jan 12, 2009 | 03:02 PM
fldodge4x4's Avatar
fldodge4x4
Default Transmission trouble. need my truck help!
I went to the car wash about a week ago. It was one of the do it yourself things. Anyway I didn't spray under the hood or anything but when i went to drive away it felt like it was bogging out especially from dead stops. I checked my codes and P0700 Internal TCM came up. I have no idea what that is. After driving a few times Everything went back to normal. Now i I went again this week and the same thing happened. But now its not coming backing to normal. I assuming something got wet but what is it that got wet. Like I said its just bogging out when I floor it especially from a dead stop but if i floor it in neutral its fine. Whats going on? I need my truck for school
Old Jan 12, 2009 | 06:53 PM
rtdakota2001's Avatar
rtdakota2001
mighta gotten some H2O under the cap and rotor. could also be an exposed wire getting pissed off when its wet. year, model, and engine might help too.
Old Jan 13, 2009 | 12:42 PM
fldodge4x4's Avatar
fldodge4x4
2000 dodge dakota 4x4 4.7v8
Can someone please show me where this stuff is located. I missed my first class of the semester because of this.
Old Jan 13, 2009 | 01:45 PM
User's Avatar
User
Haynes manual from autozone is your best friend!
Old Jan 13, 2009 | 03:03 PM
rtdakota2001
well, at least you didnt get any water in the distributor!
Old Jan 14, 2009 | 04:10 AM
fldodge4x4's Avatar
fldodge4x4
got the manual just dont know what to look for.
Old Jan 14, 2009 | 05:16 AM
User's Avatar
User
I did a search on the code.
Came up with this info from Custommagnums.com
Originally Posted by SXTitUP
UPDATE:
If you experience the issue on this post, head to a dodge/chrysler dealership and buy a Qt of ATF-4 ($9). Add that to your car and then go test drive it and see if the problem goes away. If not, pay the $70 bucks to have your car checked out or just pay the 140 to have your transmission fluid changed (it wont hurt to this anyway).
i took the leap , based on the computer code p0700, and purchased a TCM ($240) and flashed it ($80). still i had the problem up until today when i finally decided to go change the tranny fluid. the problem is finally gone and i am no longer afraid to beat my car.
So, in conclusion lol, try adding a $9 qt of tranny fluid first, and then go from there.
- Omar
Old Jan 14, 2009 | 07:50 AM
JBs DAK's Avatar
JBs DAK
Same problem -kinda,.. My Ram had no 1st gear after plowing 2 days ago.
It also thru a code,.. I was 2 1/2 quarts
low on trans fluid. Did a test drive, still no 1st gear. (Thought to my self; oh great, time
for a re-build). Cleared the code,.. Trans is fine! I'm changing the filter and fluid today
before going out to plow again 1st.
Old Jan 15, 2009 | 07:09 PM
fldodge4x4's Avatar
fldodge4x4
Default Update
went to the junk yard and pulled a tcm transmission control module. (the thing behind the head light) out of a durango. Installed it and yet the same problem. I notice that if i
manually put it into first gear
shut it off do the check codes thing 3 times with they key
then drive.
it will work for a little bit (sometimes) but then goes back to running like crap. extremely slow especially from stop lights. What do I do? I just might bring it to dodge
Old Jan 16, 2009 | 01:15 PM
blowndakota5.9's Avatar
blowndakota5.9
yeah i actually had a similar problem in my durango (before she was totalled) and i spent weeks trying to track down the problem. after hundreds of dollars in parts and a lot of me being pissed off i replaced the plug wires and BAM no more problem. i was gettin mis-fires like crazy.
