Buying a lift, need help
Old Jan 24, 2009 | 03:33 PM
rickmeseke's Avatar
rickmeseke
Default Buying a lift, need help
so I just got my 02 dakota 2wd 4.7 quad for xmas. love it, yes.
thing is immaculate, only 50k miles on it, parents got it for an excellent price. gas could be a tad better, but thats what i get from upgrading from a car i guess.
so, im looking to get a lift; body or suspension, whatever the best deal is i can find. ive found 3" body lifts for 249.99, which i feel is a reasonably good price.
now i also found this:
http://www.streetsideauto.com/produc...YMM&Reset=True
it being alot cheaper, does anyone have experience from this site, and how much higher exactly would my truck be?
sorry, im not a big mechanic fan, i just want my truck to look badass more than it is already
thanks
Old Jan 24, 2009 | 04:07 PM
f0x672's Avatar
f0x672
its going to lift the front end above the rear end. as long as your axle sits under your leaf springs on the rear axle, its a good route to go.
Old Jan 24, 2009 | 04:09 PM
rpowell's Avatar
rpowell
congrats, I love my 2003. because of our torsion bar ( I am assuming you do too) front ends lifts are not cheap around $1000. what most of us do is crank the torsion bars up and put blocks in the back. this will allow up to (I think) 33" tires w/o issues. I have 32's (actual 31.6" close enough ) on mine and don't have probs.
Old Jan 24, 2009 | 04:31 PM
RoaminGnome's Avatar
RoaminGnome
Is there a way to tell if the torsion bars have already been done? My truck sits level but my leaf springs could be sagging. I want to crank my torsion bar 2" and get blocks but i dont wanna over crank them.
Old Jan 24, 2009 | 05:42 PM
rpowell's Avatar
rpowell
Get under the truck and look at the keys, if the arm where the bolt goes through is touching the body then they are cranked all the way if there is space then you can crank some more. Hope that helps
Old Jan 24, 2009 | 05:59 PM
RoaminGnome
Sure does, thanks
I havnt looked but is there a pic of where the bolts are? Ill search before I check but if anyone has a pic or a link handy thatd be great
Old Jan 24, 2009 | 07:03 PM
varsis's Avatar
varsis
spring flip and that lift sounds like a plan, but why lift a 2wd might i ask?
Old Jan 24, 2009 | 07:09 PM
rickmeseke's Avatar
rickmeseke
to make it look sporty
Old Jan 24, 2009 | 07:22 PM
varsis's Avatar
varsis
ic, atleast you got a v8 to power bigger tires. my v6 was a dog with 31's...
Old Jan 24, 2009 | 08:39 PM
dualdakota01's Avatar
dualdakota01
i could be wrong.......but im pretty sure the 2wd daks don't have torsion bars... only the 4x4's. so no torsion option with this his truck
