PO720 code
Old Feb 10, 2009 | 01:15 PM
swkmtnbkier's Avatar
swkmtnbkier
Default PO720 code
99 Dakota 5.2 4 wh drive
Have this code. Changed output speed sensor on the tranny and the rear differential.
After resetting the check engine light comes back on just after 15 miles an hour.
Any suggestions ??
Old Feb 10, 2009 | 01:41 PM
varsis's Avatar
varsis
Any suggestions ??
corroded wire some where maybe? Also could have a tooth or something missing in the diff but i dought that option. Im thinking the wire.
Old Feb 10, 2009 | 03:03 PM
master tech's Avatar
master tech
Site Moderator & Tech
The rear sensor is for the ABS and the other is for the transmission. If you have P0720, thats for the trans.
Old Feb 15, 2009 | 09:00 AM
frostymugs's Avatar
frostymugs
I have this same problem, what took care of it? truck even acts like its missing, won't pull overdrive! so i changed cap and rotor and plugs just to rule that out but same thing still.
