Help Me Please!!!
Old Feb 16, 2009 | 03:02 PM
dodgetruckpimp's Avatar
dodgetruckpimp
Question Help Me Please!!!
So a couple weeks ago my truck threw the code P308 (cylander #8 Misfire Detected) so i ran a can of seafoam through the gas tank and pulled the plug out of cylander 8 and it was cracked. Ok yep that will do it i thought and replaced the plug and wire. about a week later it starts throwing the code again P308 WTF?? i pull the plug again and it's fine,only a week old and still looks brand new. So What else could be causing the misfire in cylander 8?
Old Feb 16, 2009 | 03:39 PM
CSCustomCars's Avatar
CSCustomCars
Check your cat.
Not sure about dakota's but on the ram's a clogged cat will cause a cyl 8 misfire.
Old Feb 16, 2009 | 05:08 PM
dodgetruckpimp
I should also mention that the Cat was replaced last year and i also replaced all the plugs, wires, cap, and rotor?
Old Feb 16, 2009 | 07:06 PM
wink2873's Avatar
wink2873
how about year/engine? that might help
Old Feb 17, 2009 | 05:50 PM
dodgetruckpimp
it's a 99 dakota 5.2L V8 4X4
Old Feb 17, 2009 | 07:50 PM
wink2873's Avatar
wink2873
does it run like its misfiring? I honestly dont know what would cause a plug to crack other than maybe the head is warped.
Old Feb 18, 2009 | 04:26 PM
dodgetruckpimp
it had a miss before i changed the plugs but now it seems to run fine, but i cleared the code twice and it keeps popping back up?
any other suggestions???
Old Feb 18, 2009 | 06:47 PM
wink2873's Avatar
wink2873
how did you go about clearing the code?
try removing the positive and negative battery cables and then touching them together for a few seconds.
Old Feb 18, 2009 | 08:57 PM
dodgetruckpimp
i cleared the code with my superchips programmer
Old Feb 18, 2009 | 10:38 PM
wink2873's Avatar
wink2873
i think it may still be stored in the computer, try the battery cable thing. as long as its running ok i dont think you have any problem.
