Axle vent leaky !!!
Old Feb 25, 2009 | 11:12 PM
dodgeramguy85's Avatar
dodgeramguy85
Originally Posted by magnethead
WOW....that's ALOT of overflow, to be pushing hydraulic gear oil that thick/heavy, up a 3 foot 3/8" diameter tube....I myself would have already drained it and popped the cover, myself. I'm with Varsis- either you got water in your diff, or something, causing it to boil/foam, and come out the tube. Maybe even check for worn teeth and/or gear lash?
Is your diff open, limited slip, detroited, or air/electric locker? I know the LSD requires a specific gear oil...
well ive drained the oil and added new stuff and its doing the same thing. the only thing i hear out side the truck is my magnaflows and my 31in bfg's all terrains. my truck is all stock except for the exhaust. whats the chances that two 98 dakotas are doing the same thing my friends is pushing out oil just not as much. I added right amount of fluid what do you think about adding a overflow bottle? If it wasnt going to rain tomorrow i would take off cover and take pics of it maybe ill clean out garage so i can fit my truck back in there lol
DakotaDodge sorry for over taking your thread
Old Feb 25, 2009 | 11:20 PM
magnethead's Avatar
magnethead
bottle = good idea. contains mess, less loss, auto-refil.
Just have a little hole so pressure doesn't build Icommon knowledge) and make sure where the tube comes in, is the lowest point in the bottle.
Old Feb 25, 2009 | 11:40 PM
dodgeramguy85
Ok I just wasnt sure if it should still get some sort of air but I guess if its pushing that much oil out it doesnt need a lot of air. Thanks
Old Feb 25, 2009 | 11:59 PM
magnethead's Avatar
magnethead
Here's how I understand it. Please do correct me if wrong
In a radiator, the fluid is pushed into the can, but because the system is a closed loop pressurized system (where the pickup is always submerged), once the volume of the cooling system reduced, it creates a vacuum, sucking the coolant back out of the bottle and into the system.
A differential isn't pressurized, nor is it closed loop. So you almost want a setup like an IV bag, where the feed line comes out of the bottle, and is gravity fed. The fluid is forced into the bottle when it gets hot and foams, but is kept gravity-pressurized, so when it cools down, it automaticaly re-fills the differential.
Old Feb 26, 2009 | 03:18 PM
dodgeramguy85
well the guy I talked to said he did it on his dakota and he has it with a vent hole at the top of the bottle and i just emailed him back and he is going to send me a pic of it.
Old Feb 26, 2009 | 04:06 PM
magnethead's Avatar
magnethead
yup. That's all that you need, that i know of.
Old Feb 26, 2009 | 04:10 PM
dodgeramguy85
Thanks for your help
Old Feb 27, 2009 | 06:58 AM
DakotaDodge's Avatar
DakotaDodge
Exclamation and I ?
I wish an answer to my problem, please!
Old Feb 27, 2009 | 11:34 AM
ibcnul8r's Avatar
ibcnul8r
Originally Posted by DakotaDodge
I noted that after to run around 50 miles, at examinate the differential, there was a oil leaky coming from the axle vent of the diff. This only happens when I go to a highway, not in a small curse.
I looked the axle vent, it was normal, no obstructed or cracked. I changed the oil thinking that it was old. The Pick-Up manual specified 75w140. I put on the nivel marked on the case and did a test, but the leaky keeps going on. There's no leaky in other place, just there. There's no odd sound from the diff. How can I fix this?
For cripes sake man.....didn't you read your own stuff before you posted it???
"Not in a small curse"?? What the hell is that?
"I put the nivel"???.....What the hell is a nivel??
Anyway...it sounds to me like something is causing a blockage somewhere in that line of yours. Or restricting the flow of fluid. Did you call a dealer service department and run the question by them?
Old Feb 27, 2009 | 12:26 PM
DakotaDodge
Thumbs up
1. small cOurse.. hahah, sorry!
2. at the level of the bottom of the check plug hole.
I'm living in brazil, dude. Not a dealer service in here. That's the reason i use a forum.
