trying to understand TB sizes
Old Feb 26, 2009 | 06:51 PM
magnethead's Avatar
magnethead
Default trying to understand TB sizes
(i know, hard hashed topic..it needs it's very own sticky almost)
Looking at another forum, it says that the 3.9 V6 is 48mm and the V8's are 50mm, with the venturi's being 2mm smaller for the torque band. But that the V6 manifold is only 46mm??
If that's right...i don't see the effectiveness of a V8 TB on V6? Unless you pull the whole thing off the block and take the die grinder to the intake as well?
Old Feb 26, 2009 | 07:12 PM
batman13's Avatar
batman13
well, its still less restriction, whats gonna happen is that the map sensor will read more incoming air...so it'll add more fuel.
the biggest impact is throttle response
Old Feb 26, 2009 | 07:16 PM
magnethead's Avatar
magnethead
okay
what kind of material thickness is there on the intake. Like, could it be bored out via die ginder (off the motor of course, to contain metal shavings) on the work bench and only have to replace the gaskets, or is there next to no removable material?
guess to paraphrase, could it be done to where it's basically the stock V8 TB, with that 2mm overall gain, then take those 2mm off the intake as well, so it's a matched 48mm? Instead of 50mm blades, 48mm vanturi, and 46mm manifold? I'd want to keep that venturi to salvage some bottom end
Old Feb 26, 2009 | 08:43 PM
batman13's Avatar
batman13
i know mine has tons of stuff that can be ground off, i have a ported/polished 4.0 TB on my 2.5, i can take plenty off my intake,
Old Feb 26, 2009 | 10:17 PM
rtdakota2001's Avatar
rtdakota2001
they have plenty of material that's able to be taken off. i opened a stock V8 to 50~51mm with just a dremmel and some wire bits and sandpaper. DO NOT open up the TB around the blades as it will freak out the IAC and cause a surging and erratic idle. IF I WERE YOU i would just get a V8 TB and do the home made P&P job like i did. it really smoothed out my idle and gave me better throttle response.
Old Feb 27, 2009 | 12:41 AM
magnethead's Avatar
magnethead
That's what i plan to do. Grab the V8 TB and cable, then see if i can mock up some sort of CAI that goes behind the lower bumper and uses the lower inlets. Maybe down the road pull the intake manifold off the block, and take the die grinder to it. I would need to scrape off the old gaskets going to the cyl heads, correct? Or is a semi-solid sealer put there instead?
I just want to throw a stock V8 TB on it- not ported out or anything- and down the road, open up the extra 2 mm's on the intake manifold. Because i want to keep the venturi effect so there's still some low-end.
