2004 Dodge Dakota Blower Motor
Old 03-02-2009 | 10:01 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
Default 2004 Dodge Dakota Blower Motor
My blower motor doesn't work. I hook up manifold gauges to do a performance test on the a/c. The high speed for the blower stopped working. I drove it outside and the blower stopped working all together. Its not the blower. I tested that, its fine.
Any ideas on what it could be?
Thanks,
Tyler
Old 03-02-2009 | 10:10 PM
Infantry-Soldier's Avatar
Infantry-Soldier
My 03 dakota, the heat/ AC only works with the **** set to full blast. Anything else it doesn't work.... Been like it since I bought it used a few years ago.... So its either full heat, or no heat... kinda sucks.
Old 03-02-2009 | 10:14 PM
magnethead's Avatar
magnethead
anytime i've had that issue, it was always the multi-point resistor that has the hot coming in and different outputs for speed.
Old 03-02-2009 | 10:20 PM
01SilverCC's Avatar
01SilverCC
It's the blower motor resistor pack. It's a common problem on Dodges. A new one at the dealer is about 15 bucks. 10 minutes to replace. Get the new one at the dealer, they recently did a redesign on the part with even better and longer lasting components.
Jimmy
Old 03-02-2009 | 10:22 PM
Infantry-Soldier
Nice, thanks.
Old 03-02-2009 | 10:24 PM
magnethead's Avatar
magnethead
Jimmy
our 77 GMC dually and 87 camaro had it fail too. I think it's a common failure on anything.
tamcnally's Avatar
tamcnally
Hey thank you very much. ill give that a shot.
Trending Topics
Old 03-03-2009 | 04:09 PM
tamcnally's Avatar
tamcnally
I looked into the problem more in depth today, it wasnt the resistor pack it was the wiring harness that plugs into the resistor. it looked like it got shorted out and melted together. the plug was all burnt up and a new harness is 72 at the dodge dealer, so i am going to try and make a new plug myself.
Old 03-03-2009 | 04:31 PM
magnethead's Avatar
magnethead
Had that happen before too. Think it was the dually as well. resistors make heat...we know that heat does to plastic.
Old 03-03-2009 | 06:23 PM
01SilverCC's Avatar
01SilverCC
If it got hot enough to melt the connector I would replace the resistor pack too. Maybe a junk yard will have the connector plug for a lot less.
Jimmy
Quick Reply: 2004 Dodge Dakota Blower Motor
