fog lights
Old Mar 5, 2009 | 05:02 PM
big.bryant's Avatar
big.bryant
i have seen guys that can bypass the **** (even on factory equipped vehciles) to where the fogs are on when the engine is on... regardless my fogs are one when my engine is on (since i always put them on) and they don't burn out, so it sounds like the previous owner did a bypass and messed it up which is why the are burning out like you had mentioned...
Old Mar 5, 2009 | 05:43 PM
magnethead's Avatar
magnethead
that's basically what i'm thinking, that the previous owner used wiring that might have been too small and causing an undervoltage condition, or another problem.
Like I said, see if you can volt meter both sockets and compare to battery volts.
