ac issue
Old Mar 6, 2009 | 09:28 PM
bgibb68's Avatar
bgibb68
Default ac issue
since i can't really search for ac here's my issue/question:
after sitting for awhile if you turn on the ac it'll work just fine, very good actually. but after about 10-15 mins, the compressor's clutch will just disengage and not work. and then after awhile it may engage and work for about 10 mins and then dissengage.
so here's my question, is this an elec problem with the clutch kicking off and on or is the compressor itself on the fritz??
Old Mar 7, 2009 | 02:50 AM
big.bryant's Avatar
big.bryant
have you checked the obvious, such as a worn/loose belt?
Old Mar 7, 2009 | 09:39 AM
bgibb68's Avatar
bgibb68
yeah the belt's good
Old Mar 7, 2009 | 10:39 AM
f0x672's Avatar
f0x672
its not the compressor. it could either be a system switch either going bad or noticing a problem in the system.
Old Mar 7, 2009 | 12:08 PM
bgibb68's Avatar
bgibb68
thanks fox....that's what i was hoping....i really don't wanna have to replace everything...but now to track down a gremlin....BAH
any ideas of where to start and how to track it??
Old Mar 7, 2009 | 12:30 PM
f0x672's Avatar
f0x672
get yourself a chilton manual to start. let me see what i can dig up for ya
Old Mar 7, 2009 | 12:40 PM
bgibb68's Avatar
bgibb68
got one....it said something about a pressure switch with the system having to high/low which i'll check when i get it to my house but the system was leak tested last year or year before and there wasn't one. and it's been like that since last summer/fall
Old Mar 7, 2009 | 01:04 PM
f0x672's Avatar
f0x672
are you just letting the truck idle and sit in place when you do this or are you moving? IMO, the cooling fan can only do so much before the system gets too hot and isnt cooling off the R-134a. thats when you need the ram air effect to cool off the condenser
Old Mar 7, 2009 | 01:25 PM
bgibb68's Avatar
bgibb68
it does it both.....it's been acting like that since last summer
Old Mar 7, 2009 | 05:30 PM
GaryC's Avatar
GaryC
jump out the high/low pressure switch mounted on the accumulator.
If this solves your problem, you might just need more refrigerant.
