98 3.9 idle when cold
Old Mar 10, 2009 | 12:12 AM
dodgeramguy85's Avatar
dodgeramguy85
Default 98 3.9 idle when cold
my friend has a 98 3.9 4x4 5 speed. Sometimes when its cold it will crank over about 3-4 times before it will run then when it does it sounds like its running on 2-3 cylinders then after about 10-20 sec's of running(at idle) it will act normal. I dont no what would be causing it to do this. For example when it was 60 out at night and after it sat for a couple hours it it will act like that but this morning it was about 40 and rainy and windy it started right up and was fine. Its like a hit and miss type of thing sometimes it will do it and sometimes it wont. Got any ideas anyone????
Old Mar 10, 2009 | 12:15 AM
magnethead's Avatar
magnethead
what was the humidity? My guess is there's condensation in the distributer, and after it arcs a few hundred times, it evaporates the water and lights that hole.
Old Mar 10, 2009 | 12:27 AM
dodgeramguy85
nope its normaly kept in a garage but it hasnt been for awhile do to a project they are doing. sat it was 65 sunny all day sat for about 5hrs and when got in to move it i pushed the clutch in and started it and it did it let it do that for about 10 sec's then its fine.
Old Mar 10, 2009 | 12:46 AM
wink2873's Avatar
wink2873
i say moisture in the distributer too. just because its in the garage doesnt mean the humidity wont get to it *unless its climate controlled*.
Old Mar 12, 2009 | 01:24 AM
dodgeramguy85
sorry have been busy but what do you recommend I tell him to do to keep this from happening ?
Old Mar 12, 2009 | 07:56 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
could try replacing the distributor if its the moisture in it if you dried it all out that SHOULD solve it, but getting a new one is never a bad idea, especially if hes got 20-30k or more on that one
Old Mar 12, 2009 | 09:57 AM
f0x672's Avatar
f0x672
mine does that to. more or less like its missing in the morning. only when cold out though.
Old Mar 12, 2009 | 12:55 PM
dodgeramguy85
Thanks for the feedback guys.
