squeeky front end
Old Mar 23, 2009 | 08:16 PM
habiak's Avatar
habiak
Default squeeky front end
hi my front end when ever i hit a bump squeeks is there a way to fix that or just put up with it?
03, 4.7 4x4 cc
Old Mar 23, 2009 | 08:34 PM
ccrunner's Avatar
ccrunner
I've tried spraying every joint I can find under my truck and it still squeaks.
Old Mar 23, 2009 | 10:08 PM
TheePlaymaker's Avatar
TheePlaymaker
sway bar bushings most likely mine does it to and i have the new bushings just haven't been able to get the 22mm deep socket yet at a time when i can do it so they haven't gotten replaced to make sure if its that for sure. i'd check that and its only like 25-30 bucks to replace them so it can't hurt
Old Mar 23, 2009 | 10:09 PM
TheePlaymaker
here is a how to on how to do it if you wanna try it https://dodgeforum.com/forum/diy-do-...geeteeohh.html
Old Mar 23, 2009 | 10:32 PM
ccrunner's Avatar
ccrunner
Thank you!
Old Mar 23, 2009 | 10:42 PM
TheePlaymaker
your welcome i hope it fixes your problem if its not that i've also heard that greasing the torsion bars with like spray lithium or silicone and also the sway bar bushings can be bad as well if the sway bar doesn't fix it but the sway bar ones are a lot easier
Old Mar 23, 2009 | 11:43 PM
habiak's Avatar
habiak
cool thanks i gotta try that
