Torsion keys
Old Apr 13, 2009 | 11:05 AM
magnethead's Avatar
magnethead
If nothing else, i suppose you could jack up the front end on the lower A arm and see if it does it?
Old Aug 20, 2022 | 02:29 AM
Dakman1's Avatar
Dakman1
Default Any1 help?
So i have a 96 4wd dakota i did the 3" lift and made it close to level with the rear since ive added the 3" lift blocks vut had to crank the torsion keys a bit and its made my axle angle so bad its ripping my axle boots 4 days after i installed new detroit axles..was wondering if anyone has ever found lower control arms n longer knuckles to hopefully correct this, very hard to find parts!
Old Aug 20, 2022 | 09:25 AM
There are companies that make 'high angle' axles, but, they are not cheap..... Another problem you are going to see is, by cranking up the torsion keys, you are losing a fair bit of suspension travel. (droop), makes for a rough ride.
Old Aug 20, 2022 | 09:45 AM
Dakman1's Avatar
Dakman1
Right have no problem loosening my tortion bars a bit but would love to find a link to those control arms!
Old Aug 20, 2022 | 11:35 AM
Drop brackets for the front diff might be easier to find......
