Front Main Seal Leak
Old Mar 30, 2009 | 05:20 PM
Fastlanefreddie's Avatar
Fastlanefreddie
Default Front Main Seal Leak
My 03 4.7L has a front main seal leak. Any idea what it takes to replace? My biggest worry is my 650 ft lb impact won't take off the harmonic balancer.
Is there a special installation tool?
Old Mar 30, 2009 | 06:24 PM
huseman808's Avatar
huseman808
you shouldnt have a problem taking the HB bolt out. You will need a puller to take the balencer itself off. Once you get the old seal out of the timing cover just get a small block of wood and a hammer to put the new one in.
Old Mar 30, 2009 | 08:42 PM
Fastlanefreddie
Does the timing cover need to come off? ALso, what is the torque on the harmonic pulley bolt?
Old Mar 30, 2009 | 10:11 PM
huseman808's Avatar
huseman808
If you remove the lower fan shroud you should be able to get to it with relative ease.
VIBRATION DAMPENER TO CRANK BOLT
3.9/5.2 = 135 ft/lbs
5.9 = 180 ft/lbs
4.7 = 130 ft/lbs
Old Mar 6, 2010 | 08:31 AM
theandies's Avatar
theandies
My 4.7 has developed the same leak. Did you replace yours OK? Anything that I should be aware of before I start? Did you have to take the timing cover off? BTW this is in a 2003 Durango. Are they the same as the Dakota 4.7 if you know?
Thanks
