idle problems surge
Old Apr 6, 2009 | 02:15 AM
badow24's Avatar
badow24
Default idle problems surge
98 Dakota 5.2l 5 speed 4x4 manual 5 speed
Cap and rotor, wires
Coil
Plugs
Cam sensor
Iac Tps
battery
fuel pressure at 46
Okay while driving there is no surge or idle problems except when coming to a stop I take it out of gear and it will surge a bit but when coming to a dead stop, the rpm's drop low 400rpm maybe less at times and the lights dim then surge to about 8 900rpm and couple times then smooth out to about 600. But if I step on the gas rev it up a bit outta gear before the stop it does'nt surge.
Thanks for any help
Old Nov 26, 2009 | 02:03 AM
badow24's Avatar
badow24
bump any new ppl with this problem ? any help very appreciated Thanks
Old Nov 26, 2009 | 02:19 AM
95_318SLT's Avatar
95_318SLT
It sounds like the IAC to me. It looks like you said you replaced it, but they can very much be bad new. I went through 3 new ones in 2 weeks before I got one that worked.
If thats not it, it could be either a vacuum leak or a bad MAP... they both lead to the same symptoms.
