Would this fit in my truck.
Old May 3, 2009 | 10:53 PM
reddakota34's Avatar
reddakota34
Default Would this fit in my truck.
1998 dakota auto 5.2L 4x4 I found this on craigslist and i was wondering if it would fit my truck and if it would be posi or not because i would rilly like it to hook up posi, and i no i would not be able to use my 4x4 after installing it. And would it make a power difference? http://maine.craigslist.org/pts/1123213442.html
Old May 3, 2009 | 10:55 PM
f0x672's Avatar
f0x672
thats the 9 1/4 axle if im not mistaken (10 bolt cover, 8 1/4 axles are 8 bolt i beleive) and yeah it should fit without a doubt.
Old May 3, 2009 | 10:58 PM
TheePlaymaker's Avatar
TheePlaymaker
yeah it should fit and you would be able to use 4wd if you have 3.92's in the front
Old May 4, 2009 | 03:30 PM
Spike300's Avatar
Spike300
it will bolt right up
Old May 4, 2009 | 03:43 PM
wink2873's Avatar
wink2873
you are mistaken
10 bolt = 8.25 axle
12 bolt = 9.25
regardless, it will fit, although I dont know what you would benefit from it. it doesnt say if its a posi or not so who knows.
Old May 4, 2009 | 09:12 PM
reddakota34
I talked to a couple of people to day and they said if i did put it in, id have to take my front drive shaft out so it wouldnt bind up is that true?
Old May 4, 2009 | 09:13 PM
reddakota34
And i would just take the whole asembaly out of that rear end and put it in mine if it would work like that, going from 3.55 to 3.92 would make a pritty good power difference.
Old May 4, 2009 | 09:51 PM
f0x672's Avatar
f0x672
Originally Posted by wink2873
you are mistaken
10 bolt = 8.25 axle
12 bolt = 9.25
haha it happens, im lucky i remember how many quarts of oil my truck needs..
Old May 5, 2009 | 12:01 AM
big.bryant's Avatar
big.bryant
yeah but then if its only an 8 1/4 then its not going to be strong enough if he does any power mods...
Old May 5, 2009 | 03:57 PM
wink2873's Avatar
wink2873
why not just buy the axle and swap the gears out? it would be a hell of alot easier than swapping the whole axle and make alot more sense. you dont know how good that junkyard axle is, it could be blown to pieces inside for all you know.
