Sticky Brakes
Old 05-10-2009, 09:07 AM
Czechman's Avatar
Czechman
Czechman is offline
My Jeep had extremely sensitive brakes after sitting overnight in wet conditions. Perhaps better lining would have eliminated the problem but just a little pressure on the brake pedal to drag the brakes will fix the problem. The heat eliminates the moisture and therefore the problem.
Old 05-24-2009, 11:00 AM
jarnkm's Avatar
jarnkm
jarnkm is offline
I'm new and in here for a similar problem ... sticking front brake calipers. At 66, this is an Old Skool problem that Chrysler has had since some idiot in Chrysler convinced them to use Phenyolic Pistons in their calipers! Old kits could be had with choice of metal or phenyolic piston ... curing said problem. Obviously, the phenyolic expands more than the steel and thus ... seizure. Quick and sometimes permanent cure, used to be, clean the piston with warm water and fine scouring pad, then a light hone on the cylinder. Roadtest in heavy traffic for sticking! If so, hone a bit more, until problem ceases. Time consuming? Possibly! Enjoyable" Could be if the amount of purchased "cool fuel" is compared with that of a caliper and hose!!
No damned wonder Chrysler is going bankrupt ... any idiots stupid enough to continue using "Phenyolic Pistons" in their brake calipers, have to be lacking elsewhere, as well.
Hope this is of interest and helps, next time.
Old 05-24-2009, 12:25 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
There are a lot of things that make me scratch my head about what Dodge does. Like yesterday when I found out my ball joints are shot at 105k and have already been done by the recall... That should never happen.
I didn't know thats what Dodge did with their brakes, but it makes sense now. Mine used to stick on my last dakota, so far so good with this one though.
Old 05-24-2009, 03:02 PM
big.bryant's Avatar
big.bryant
big.bryant is offline
my brakes are starting to suck hard... i'm going to be replacing them here in a couple days with the drilled/slotted i have in my parents garage but its bull**** that they put tiny *** brakes on such a heavy truck.... panic stops are very far from confidence inspiring, thats for damn sure
Quick Reply: Sticky Brakes
