Upper balljoints
Old May 10, 2009 | 09:26 PM
black98sport's Avatar
black98sport
Default Upper balljoints
I noticed both my upper balljoints have no grease boots. I don't know how long either. They are riveted in place with pressed studs. anyone ever remove them ?. can the studs just be grinded off ? I see replacement balljoints in various auto part stores. The stupid haynes book says to replace the whole upper control arm with a new balljoint. screw that. I prefer to replace both upper and lower while I got the spindel removed.
Any ideas would be appreciated.
Old May 10, 2009 | 09:28 PM
User's Avatar
User
Yes they can be grinded off...
what year is your truck and how many miles do you have? You might be able to get it done by the dealership for free, since there was a recall/extended warranty on the ball joints.
Old May 10, 2009 | 09:42 PM
dodgerules86's Avatar
dodgerules86
For some reason, I bet he's got a '98 sport, lol.
Yes, you can replace just the ball-joint.
At work (I don't work on vehicles), we typically drill out rivets, but however you get the rivet out is up to you.
Old May 10, 2009 | 09:52 PM
black98sport
yes it's a 98 sport. 2.5L engine 74,000 miles
Old May 11, 2009 | 12:17 PM
hunterx313's Avatar
hunterx313
Easiest way to get out the rivets is to heat them up with a torch or knock them out with an air chisel.
Old May 12, 2009 | 04:14 PM
batman13's Avatar
batman13
they are easy if you have the proper tools
like cookin with gasoline
