Clutch fan issue?
Old May 16, 2009 | 01:40 PM
Excoelis's Avatar
Excoelis
Default Clutch fan issue?
03 Dak QC 4.7 545RFE - When I first start the truck up after it has been sitting for a while, and start driving, it makes a "roaring" sound, similar to a dump truck, or moving alot of air. It usually does this for a minute or two. I'm assuming this is the clutch fan... the only thing is, it feels almost like though the truck is revving really high, it is still moving really slow, even though I rev it... kind of like the transmission is slipping or something. But as soon as the "roaring" sound stops... it has full power with no "slipping" anymore. There are no transmission issues with the truck, shifts fine etc. so does this have more to do with the clutch fan?
Old May 16, 2009 | 02:28 PM
TheePlaymaker's Avatar
TheePlaymaker
its normal they all do it i think its from all the oil being in the bottom of the clutch fan and it just has to lubricate itself again or something but mine does it and i'm sure others will agree
Old May 16, 2009 | 03:37 PM
Excoelis's Avatar
Excoelis
Thanks for the reply. Is it normal for the "slipping" feeling as well though? A better way to describe it is that it feels almost like it's in 4LO.
Old May 16, 2009 | 04:59 PM
rpowell's Avatar
rpowell
It may just be that the clutch fan takes some HP away while its fully engaged. If you have the electric fan in front of the clutch fan, then just remove the clutch fan. I have mine that way and I live in TX where it reaches triple digits all the time with no overheating issues.
Old May 16, 2009 | 07:00 PM
MrBlond's Avatar
MrBlond
Mayb try to take off the clutch fan and drive down the road and see if it still sounds bad. After I went threw my third fan I took it off and run without. My truck is a bit warmer but nothing to worry about.
Old May 17, 2009 | 01:26 AM
dodgeramguy85's Avatar
dodgeramguy85
my 98 is the same way I make it to the end of the block(about 1/4mile) and its fine. I remember my bosses 02 doing the same thing.
Old May 17, 2009 | 12:15 PM
wink2873's Avatar
wink2873
alot of vehicles do it. my truck, and all 3 of my parents fords do it too.
Old May 17, 2009 | 01:58 PM
bpark8824's Avatar
bpark8824
Yeah same here. Its common. As long as it stops after just a minute or two you're fine. I know my truck and my fathers both do it. Especially on cooler mornings with not much time to warm up or like you mentioned has been sitting for a few days.
Old May 17, 2009 | 04:46 PM
f0x672's Avatar
f0x672
yeah, the clutch fan does rob about 5 horsepower.. just be happy its not a class 8 truck clutch fan.. they rob about 45 horses
Old May 17, 2009 | 04:59 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
it is 1hp lost per inch of fan.
