Is this the radiator drain plug?
Old May 23, 2009 | 04:16 PM
((Vibe))'s Avatar
((Vibe))
Default Is this the radiator drain plug?
If it is then I might be in trouble because the plastic turn **** part has been broken off of it. I was in the middle of flushing my cooling system but hadn't opened the drain plug yet, so now the system is full of tap water....what should I do?
Old May 23, 2009 | 05:58 PM
dodgerules86's Avatar
dodgerules86
Yes, that looks like the drain plug. I'd suggest getting a new drain plug and doing "whatever you have to do" to get the old one off.
Some channel locks should do the trick though, before having to go to "extreme" measures like punching a screw driver through it.
Old May 23, 2009 | 07:21 PM
bpark8824's Avatar
bpark8824
Channel locks or vise grips are always the tools that come in handy w/ something like that. Becareful not to break it through.
Old May 23, 2009 | 07:41 PM
((Vibe))'s Avatar
((Vibe))
Nah, channel locks and the like won't work because there is nothing there to grab onto. I tried to make a tool by cutting a V into a flat head and trying to jam it in there but it didn't really work either.
I ended up draining it from a plug on the back of the t-stat housing.
Old May 23, 2009 | 11:06 PM
rtdakota2001's Avatar
rtdakota2001
is it metal? what kind? weld a nut on it then use that to break it loose.
Old May 23, 2009 | 11:22 PM
Hahns5.2's Avatar
Hahns5.2
Pull the lower rad hose off...
Old May 24, 2009 | 12:37 AM
dodgerules86
No, it's a plastic drain plug.
*edit* He could try using some of that plastic glue stuff (my local auto parts store has about 10 different kinds). I don't know how good it really is though.
