2000 dakota 2wd, 4.7l front caliper thread size????
I have a small problem. I need to know the OEM thread size for the caliper pin / bolt that attaches to the steering knuckle.
I had the common problem of stripped threads and I think I was sold the wrong helicoil b/c after getting 2/3 of the way in, it binds and strips the threads of the new pins (3 of them). I need to verify that I have in fact installed the wrong helicoil before I do anything else
I fear that the only way out is to have a set of custom bolts made to the "wrong" thread count.
Any one know where I can get custom bolts made?
Thanks.
Thanks.
Here's how I repaired mine. I have a 2000 2wd.
Technical Service Bulletin
Front Caliper Mounting/Steering Knuckle - Thread Repair
NUMBER: 05-03-99
GROUP: Brakes
EFFECTIVE DATE: Apr. 23, 1999
SUBJECT:
Caliper Mounting To Steering Knuckle Thread Repair
OVERVIEW:
This bulletin involves repair of the threads on the steering knuckle or brake caliper mounting adapter that are used to install and retain the front brake caliper housing in its correct operating location.
MODELS:
1986 - 1999 (AN) Dakota
1998 - 1999 (DN) Durango
DISCUSSION:
A Brake Knuckle Thread repair kit has been developed to repair stripped threads on the front brake caliper mounting attachment making it no longer necessary to replace the front steering knuckle/brake caliper mounting adapter when encountering stripped threads. The following information provides the repair procedure for using the Brake Knuckle Thread Repair Kit.
DIAGNOSIS:
1. Place the vehicle on an appropriate hoist.
2. Remove the front tire/wheel assembly.
3. Remove the brake caliper housing assembly by loosening the mounting bolts.
NOTE: IF HIGH TORQUE IS ENCOUNTERED DURING THE MOUNTING BOLT REMOVAL, IT IS LIKELY THAT THREAD DAMAGE WILL OCCUR OR HAS OCCURRED.
4. Remove the caliper housing assembly and hang the housing on the frame of the vehicle using an appropriate wire hanger.
NOTE: DO NOT ALLOW THE CALIPER HOUSING TO HANG BY ITSELF FROM THE BRAKE HOSE AS DAMAGE TO THE HOSE MAY RESULT.
5. If the vehicle has a bolt-on brake caliper mounting adapter, remove the adapter. If the brake caliper mounts directly to the steering knuckle, remove retainers on the wheel studs and remove the rotor.
6. Inspect the mounting bolts and knuckle threads for damage. If either is damaged, it is likely that damage to the other has occurred as well. If damage has occurred to the threads in the form of knicks, thread pulling, or cross-threading, perform the Repair Procedure.
PARTS REQUIRED:
AR (1) 05016156AA Insert, Heli-Coil, M9 X 1.25
AR (1) 04886075AA Bolts, Caliper Housing Mounting
EQUIPMENT REQUIRED:
AR (1) 05016155AA Kit, Brake Knuckle Thread Repair
Includes:
23/64 Drill Bit
M9 X 1.25 Tap
Heli-Coil Installation Tool
Heli-Coil Tang Break-Off Rod
(25) M9 X 1.25 Stainless Steel Heli-Coils
REPAIR PROCEDURE:
1. Using the 23/64 in. drill, drill through the brake caliper mounting attachment hole keeping the drill perpendicular to the knuckle.
2. Using the M9 X 1.25 tap, tap the drilled hole ensuring to tap the hole entirely through.
3. Install a Heli-Coil insert onto the installation tool (tool number 3747-9). Be sure the tang is properly engaged into the driving contour of the tool.
4. Install the Heli-Coil into the drilled/tapped hole by rotating the tool and exerting slight pressure onto the tool/Heli-Coil and into the drilled/tapped hole. Continue to rotate the tool until the insert is located 1/4 to 1/2 turn below the steering knuckle surface.
5. Back the Heli-Coil installation tool out of the installed Heli-Coil. Then, remove the tang from the Heli-Coil by breaking the tang off using the tang break-off tool. Place the break-off tool into the assembled insert until it rests on the Heli-Coil tang. Holding the tool squarely, strike the tool sharply with a hammer.
6. If the vehicle has a bolt-on brake caliper mounting adapter, install the adapter. Refer to the appropriate Service Manual for information regarding proper brake caliper adapter mounting information. If the brake caliper mounts directly to the steering knuckle, install the rotor.
7. Install the caliper using new mounting bolts p/n 04886075AA in any location that had a Heli-Coil installed. Tighten the bolts to 30 - 35 N.m (22-26 ft. lbs.).
8. Install the tire/wheel assembly.
9. Lower the vehicle.
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No:
05-80-20-93 Brake Caliper Mounting Support Thread Repair,
Left Side 0.4 Hrs.
05-80-20-94 Brake Caliper Mounting Support Thread Repair,
Right Side 0.4 Hrs.
05-80-20-50 Brake Caliper Mounting Support Thread
Repair, Each Additional Same Side 0.1 Hrs.
FAILURE CODE: XX - Service Adjustment
NUMBER: 05-03-99
GROUP: Brakes
SUBJECT:
OVERVIEW:
MODELS:
DISCUSSION:
DIAGNOSIS:
PARTS REQUIRED:
EQUIPMENT REQUIRED:
Includes:
23/64 Drill Bit
M9 X 1.25 Tap
REPAIR PROCEDURE:
TIME ALLOWANCE:
Labor Operation No:
Left Side 0.4 Hrs.
Right Side 0.4 Hrs.
Well if M9 x 1.25 is the OEM bolt thread then part of my problem is obvious; I was given 3/8 x 24 as the correct helicoil insert...off by less than half of a millimeter on diameter.
I guess I am going to have to get some custom bolts cut because naturally the hole I drilled was 25/64 so there is no way to re-drill and get the right insert in there.
