vaccum leak
Old May 31, 2009 | 07:28 PM
Josh Abels's Avatar
Josh Abels
Question vaccum leak
so my check engine light came on and took the truck to my local advanced and had them do the plug in thing, they said it was a vaccum leak, is there a common place that this could be coming from, or what i could do to find out where it is.
Old May 31, 2009 | 08:15 PM
f0x672's Avatar
f0x672
the trouble code will be nice, so we can help you out
Old May 31, 2009 | 08:16 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
first check is the gas cap being loose, the second thing is, on my dads truck there is a vacume hose that runs under the battery, tend to dry out and crack on the end, if thats it, cut off the cracked part and put the hose back on the connector
Old Jun 1, 2009 | 08:04 AM
Josh Abels's Avatar
Josh Abels
sorry they didn't give me the trouble code and i will check the hose under the battery see if that could be it
Old Jun 1, 2009 | 12:11 PM
Billiam's Avatar
Billiam
Check this thread. I may help you a bit..
https://dodgeforum.com/forum/2nd-gen...read-this.html
Old Jun 1, 2009 | 03:22 PM
batman13's Avatar
batman13
quick easy way to find a vacc leak is to spray each connection with starting fluid with the truck running,
if it starts to run funny, theres your leak
