42re tail shaft/housing 2wd to 4wd swap
Old Jun 14, 2009 | 01:47 PM
charliek's Avatar
charliek
Default 42re tail shaft/housing 2wd to 4wd swap
Hi,
First time poster, long time lurker. I"ve got a issue with my '01 Dak 4x4 and am hoping for a little help here gents so here goes...
Pooched reverse in the 42re and initial findings after dropping the pan and screen showed good fluid, no shavings, minimal material on the magnet (looked like a3/32 covering of fine never seize) but I did find what appears to be part of of the (I'm guessing a bit here) the direct clutch waved ring. All forward gears and TC work well however no reverse and no engine braking in 1st gear manual, pointing to low/reverse-band/servo failure. Long story short guys, tranny has 150k on it and I've found a low mileage 2wd 42re for short money. Is a housing/tail shaft swap with my 4x4 setup as donner feasible ie a simple swap out or does it require a internal tranny break down. Thanks for any insight.
Charlie
