what trans will fit my 97 Dakota
The auto trans in my 97 Dakota 2 w/d v/6 is shot. What model years will fit it? Some of the ads I see say that 97 is all by itself. If so is it a matter of having to change a sensor or something or will others just not fit? THANX in advance for your help
44re, and 46re, were also offered on these trucks 97-04 behind the 5.2 and 5.9 motors. These should bolt up and function just fine behind your v6 as well I believe, but I may be mistaken about this.
the 3.9, 5.2, and 5.9 all used the same transmissions. you could pull one off another truck that had one of these engines and you'll be able to do a direct bolt on swap.
the only difference i think is that one is man. and the other is auto?
