TPS mod
Old Jun 19, 2009 | 02:09 PM
rpowell's Avatar
rpowell
Default TPS mod
Searched, but couldn't find it. Can somebody post the link?
Thanks
Old Jun 19, 2009 | 02:17 PM
f0x672's Avatar
f0x672
drill out the brass inserts from the TPS, and mount it back onto the throttle body, with washers on the screws to keep it in place, will slide off without washers. then turn the tps until .7V is read on a multimeter on the signal wire back to the pcm at idle. however, if your TPS sends approx .65V at idle back to the pcm, dont bother with the mod, it's not a significant enough increase for the butt dyno. my tps is still unmodified, and reads like .67V at idle.
Old Jun 19, 2009 | 02:21 PM
rpowell's Avatar
rpowell
Thanks I knew there was a "7" in it, but couldn't remember if it was .7 or 1.7. Wouldn't happen to remember which wire is the signal wire would you?
Old Jun 19, 2009 | 02:31 PM
f0x672's Avatar
f0x672
center wire
Old Jun 21, 2009 | 02:29 AM
rpowell's Avatar
rpowell
ok after the mod I can only get it to .8v at idle. Will this be close enough or should I keep going till I get at .7v?
Old Jun 21, 2009 | 11:38 AM
f0x672's Avatar
f0x672
the mod is supposed to correct the output voltage if it's lower than .7v, no higher than that.
Old Jun 21, 2009 | 04:53 PM
RoaminGnome's Avatar
RoaminGnome
Ill be a n00b, what do you gain from the TPS mod? It sounds easy and free but what will I get from it?
Old Jun 22, 2009 | 01:57 PM
rpowell's Avatar
rpowell
I have heard guys that don't even have to mod theirs like fox672, but mine was sitting at 1.1v and I still have to adjust it more to get .7 or under, anybody else have this extreme or is it just me?
Old Jun 23, 2009 | 01:37 AM
rpowell's Avatar
rpowell
bump, bump
Old Jun 24, 2009 | 03:25 PM
TheePlaymaker's Avatar
TheePlaymaker
supposedly it also corrects back once you mod it so from what i've read in the past after a few weeks its not worth it and goes right back to how it was. :/
