wierd problem
Old Jul 2, 2009 | 11:41 AM
rpowell's Avatar
rpowell
Default wierd problem
Ok let me tell you guys what its doing and then what I have replaced.
Sometimes my truck will surge for no reason at low speed or take off. I can press the gas pedal (maybe 1/4 or less) and it will act like its gonna die, then surge a few times then all of the sudden it will take off.
I have replaced the TPS, IAC valve, O2's, Map sensor, crank sensor, coolant temp sensor, IAT sensor (think thats what it is called- air temp), removed and thoroughly cleaned the TB, new plugs, all new fluids in everything. I have not replaced the tranny fluid return filter inside the tranny pan, but will be doing so soon. I have put a pressure tester on the fuel rail and it seems to be holding pressure, I guess I could check it again.
Now comes the wierd part, when it acts up if I turn the truck off and then start it right back up, the problem goes away. I am fairly sure it's electrical, but what the heck could it be? Any help would be greatly appreciated.
Old Jul 2, 2009 | 08:27 PM
jamie's Avatar
jamie
My truck does this right after a rain, once, then it is fine until it rains again. Dunno what it is. Replacing the rotor and cap, and the plug wires helped a little.
Old Jul 2, 2009 | 08:33 PM
wingerak92's Avatar
wingerak92
He has a 4.7.... He doesn't have the cap and rotor or plug wires.
Old Jul 2, 2009 | 10:22 PM
rpowell's Avatar
rpowell
Yeah no cap or rotors, I have coil overs and they ohm'ed out ok. I have a friend (in Minnesota) who is a Dodge mechanic and he is not even sure what it could be. I am trying to get it diagnosed over the phone with him, but I might be doing something wrong or misunderstanding the process. I was hoping somebody else had been through this and could offer a potential fix, it's driving me crazy and hate taking my vehicles to a shop.
Old Jul 4, 2009 | 02:57 AM
fldodge4x4's Avatar
fldodge4x4
sure its not the transmission going into that limp mode thing?
Old Jul 4, 2009 | 03:29 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701
deleted
Old Jul 4, 2009 | 12:19 PM
rpowell's Avatar
rpowell
Originally Posted by SPARTANENGINEER1701
lets try some thing simpile where are u getting ur gas from
2dump 2-4 cans of dry gas down the tank
3 reason why i think this , water in tank ,is on the bottom of tank,turn key
pump on, water first in engine ,then u said it runs after u restart,feedback to
tank mixed gas and water,
drygas alcohol isopropanal will make water burn.
try sunnoco gas very good to my jeep had same happen.
if it is water drop tank and clean or hole could result.
stop buying parts bro go simpile first KISS keep it simpile
let us know please
Appreciate the idea, I will try that. I have been replacing sensros because I have high miles, so it's not a big deal about buying them (was going to anyway). The way it runs is getting on my nerves though, hope your idea works.
Old Jul 4, 2009 | 12:51 PM
kev2's Avatar
kev2
I completely Agree with SPARTANENGINEER1701
KISS is a motto of mine.
Always start simple..... want to add to his ideas and ask
Is the CEL on?
Is Vehicle STOCK?? Anything NOT OEM?
EDIT IN
Some reason I cannot see the info when I am posting- this is your truck mods?
"CAI, Yokohama A/T-S, F.M., K&N, SuperChips"
Old Jul 4, 2009 | 01:13 PM
rpowell's Avatar
rpowell
Is the CEL on?
EDIT IN
No CEL, you can read my sig as far stock or not goes, nothing major, but I may take the tune off and see if it helps. I detuned once before, now that I think about it, and it didn't seem to help. Only things I could think of is week fuel pressure regulator, something electrical (so I replaced a couple sensors) or was wondering if the return filter for my tranny cooler was real dirty could it affect things at start up? I am about to pull my tranny to put a kit in it (because I am about to regear) and am going to replace return line filter then. Thanks for the brainstorming guys.
Old Jul 5, 2009 | 04:17 AM
SPARTANENGINEER1701
deleted
