Liftting for newbies
Old Jul 14, 2009 | 11:24 PM
Papa Bo's Avatar
Papa Bo
Default Liftting for newbies
Hey all
i just bought a 98 2wd dodge dakota extended cab. i want to lift it up but am unsure how much to lift it. also i need some inside information on what customizations i need to do to put a lift kit on a 2wd.
Old Jul 14, 2009 | 11:26 PM
rtdakota2001's Avatar
rtdakota2001
welcome welcome. with a 2 wheel drive i would say a body lift should suffice. oh, by the way, where in Illinois?
Old Jul 14, 2009 | 11:36 PM
Papa Bo's Avatar
Papa Bo
tinley park, its like 30 mins south of chicago
Old Jul 14, 2009 | 11:41 PM
Papa Bo's Avatar
Papa Bo
ive been reading online forums for the past few hours, but what all do i have to change to put a body kit on my truck. for example i read something about switching the rear leaf springs above the axel... what else is there
Old Jul 14, 2009 | 11:47 PM
95_318SLT's Avatar
95_318SLT
Switching to axle under spring is a bad idea for a 2wd. It will give you about 4-5 inches of lift in the rear that cannot be compensated for in the front and your truck will be pitched way down in the front.
A body lift requires no suspension modifications at all. You basically just need to unbolt the body from the frame and slide spacers inbetween and extend anything that needs extending to reach.
If your set on a suspension lift, you could get longer shackles in the back and 1-2" spacers for the coils in the front.
Old Jul 15, 2009 | 12:48 AM
Papa Bo's Avatar
Papa Bo
whats the pros/cons of a body lift? and the pros/cons of a suspension lift?
Old Jul 15, 2009 | 02:01 AM
95_318SLT's Avatar
95_318SLT
Pros for a body lift:
Cheap, easy, and gives you clearance for bigger tires
Cons:
Doesn't increase suspension travel or ground clearance (except for the clearance you get from bigger tires).
Pros for suspension lift:
Increases suspension travel. Adds ground clearance. Allows for bigger tires (which add more ground clearance).
Cons for suspension lift:
Unless you fork over a heck of a lot of cash for drop control arm mounts, lifting using springs cause a harsher ride and puts more wear on tie rods and ball joints. The expensive lifts (I don't know of any for the 2wd front suspension) keep the factory angles on all the components, but like I said, they are expensive.
If anyone can think of other pros and cons, feel free to add them to my list.
Old Jul 15, 2009 | 09:31 AM
Josh Abels's Avatar
Josh Abels
for a suspension lift i can only think of two different types the fabtech and doetsch tech
i believe they are pretty much the same, the fabtech just comes with ball joints and is more expensive
the con to these is you have to get new wheels with smaller backspacing
http://www.doetsch-shocks.com/17.asp
http://www.fabtechmotorsports.com/ap...tadurango.html
Old Jul 15, 2009 | 12:05 PM
Papa Bo's Avatar
Papa Bo
so if i wanted a 6 inch lift which i cant seem to find.... and dont think is made. is it possible to do a 3" suspension lift and 3" body lift to achieve the total of 6 inches i want?
Old Jul 15, 2009 | 12:14 PM
Josh Abels's Avatar
Josh Abels
i believe so
