Is my fan clutch bad?
Old Jul 27, 2009 | 11:21 PM
heavyjay's Avatar
heavyjay
Default Is my fan clutch bad?
I've noticed that my AC doesn't blow cold at idle (sometimes it's even warm) and the temp gauge goes up above 210. While moving, the AC gets cold and the temp stays below 210. How hard should it be to turn the fan when the engine is hot? I can turn mine with one finger. It won't freewheel, but it is very easy to turn.
'98 Sport, 3.9, no auxilliary AC fan.
Old Jul 28, 2009 | 12:53 AM
Independentfool's Avatar
Independentfool
your fan clutch is fine.
the engine gets warmer simply because the fan cant move as much air across the rad as just driving does.
pretty much the same reason for the A/C blowing warmer at idle, but its the condenser thats not getting as much air flow. You could try adding some freon to your system, but i dont think it will help much.
Old Jul 28, 2009 | 01:17 AM
big.bryant's Avatar
big.bryant
get your A/C system checked out... it could just need a new charge or you might have a leak somewhere...
So you don't have the electric fan that comes on when you turn on your A/C? I thought most came with that...
Old Jul 28, 2009 | 10:22 AM
heavyjay's Avatar
heavyjay
Apparently, the '98 regular cabs don't have an auxiliary fan. I don't think it's leaking, it will freeze you out as long as you're doing 35 mph or better.
Old Jul 28, 2009 | 10:33 AM
f0x672's Avatar
f0x672
if i remember correctly, a vehicle sitting with the a/c on will have a temp output 10 degrees higher than when the vehicle is moving. a/c murders fuel mileage in stop and go traffic anyway. hell even at 70 mph, doing hand calculations, windows down ARE still BETTER than a/c on. then again i have a v6 and it's a pig.
Old Jul 28, 2009 | 03:40 PM
heavyjay's Avatar
heavyjay
I was sitting in line at the bank's drive thru a couple hours ago. A/C was off and the temp gauge went way up. I was afraid it was going to overheat.
Old Jul 28, 2009 | 09:50 PM
big.bryant's Avatar
big.bryant
do a coolant flush...
my truck will sit all day with the engine on in 100* temps and not overheat
Old Aug 1, 2009 | 06:04 PM
heavyjay's Avatar
heavyjay
Flushed the cooling system, no difference. Temp gauge still goes way up when sitting at idle whether the AC is on or off.
Old Aug 1, 2009 | 10:25 PM
dodgeramguy85's Avatar
dodgeramguy85
What is the temp at when you are at a idle. Mine runs about 180-200 all the time also mine is the 5.2
Old Aug 1, 2009 | 10:53 PM
heavyjay's Avatar
heavyjay
It gets close to the 230 mark.
