Air blowing out vent, floor, and defrost
This is how to remove the dash to get to the A/C housing with the flaper door that is your problem I think or it may be just the cable in the dash came off its hook what ever it sounds like you need to take the dash off to look at the cables and find the problem.
http://www.dakota-durango.com/forum/showthread.php?t=98729
I do believe that some of the A/C vents are either helped out by vacuum or closed by vacuum check your vacuum lines in the engine compartment are some disconnected or broken not attached some of the vacume lines are just under the dash and easy to get to see if one may of been kicked off.
