oil pressure drops at stop
Old Aug 2, 2009 | 03:13 AM
ccrunner's Avatar
ccrunner
Default oil pressure drops at stop
I know I know, there have been manny posts on this. I must suck at searching because I can't find them. Every once in a while when I come to a complete stop the oil pressure gauge drops to 0 and the check gauges light come on. When you take off the pressure returns to normal. Is the gauge being screwy or is my pressure dropping?
Old Aug 2, 2009 | 03:24 AM
JDakota92's Avatar
JDakota92
Check out the oil pressure sending unit. I bet you'll find a huge oil leak coming from it. My '92 did the same thing. Replaced the unit and have had accurate pressure readings since. What motor do you have? If it's the 3.9, 5.2 or 5.9, it'll be on the back/passenger side on the very top behind the intake. It's a difficult one to see. Might be easiest from underneath.
Old Aug 4, 2009 | 11:57 PM
crazyaussie's Avatar
crazyaussie
Mine did the same thing when the oil level was low. Got an oil change and the issue disappeared.
Old Aug 5, 2009 | 02:48 AM
big.bryant's Avatar
big.bryant
yeah i would say first check your oil level and add if nessesairy... if that doesn't work, check out the OPSU
Old Aug 6, 2009 | 01:57 AM
ccrunner's Avatar
ccrunner
I got oil the other day just haven't changed it yet. Thanks guys.
