Again..Looking for Max Tire Size w/NO Lift
Old Aug 3, 2009 | 11:00 AM
Pete-O's Avatar
Pete-O
Default Again..Looking for Max Tire Size w/NO Lift
Hello, just like to say I'm really diggin checkin out all the nice rides on this site, its giving me some ideas....but anyway, my first step is to get new tires as my Wranglers have worn out after 68K miles. My stock tire is a 265/70R16. I want the Bridgestone Dueler ATS Revo's but can only get them in 265/75R16 , an inch taller than the 260's. Will this work with no rubs? Anyone out there that has this setup?
Old Aug 3, 2009 | 11:40 AM
revdodge600sdi's Avatar
revdodge600sdi
I just bought 4 brand new hankook dynapro M/T tires for my truck and they are 265-75-16..they are actualy a (32 inch tires says the paper the tires came with), however they are an extreamly agressive tread pattern. They are atleast an inch or so bigger that what i took out of there and no problems rubbing.. Also they didnt rub when i gave them a test run with my 7.2 western plow.. so you should be good
Old Aug 3, 2009 | 11:42 AM
revdodge600sdi
heres the tires if anyones intesrested in getting the same ones..
Old Aug 3, 2009 | 01:07 PM
ccrunner's Avatar
ccrunner
My Dueler Revos are 31.5" and they've never touched, even on the hardest turns and jumps.
Old Aug 3, 2009 | 05:47 PM
Pete-O's Avatar
Pete-O
And you are at astock height with no lift?
Old Aug 3, 2009 | 07:29 PM
revdodge600sdi
my tires are bigger than his..and yes my truck its stock with no lift..and there not even close to rubbing
Old Aug 3, 2009 | 11:48 PM
big.bryant's Avatar
big.bryant
i believe 32'' is the magic cut-off line
Old Aug 4, 2009 | 08:43 AM
Pete-O's Avatar
Pete-O
You guys are great, thanks a lot. I'm calling right now to order those Dueller Revo's.
Old Aug 20, 2009 | 05:40 AM
moparman_2004's Avatar
moparman_2004
on my o4 im running 265/75-18 dick cepeks and i had to raise the tortion bars a bit then just decided to level it and havnt had a problem
Old Aug 21, 2009 | 01:37 AM
wingerak92's Avatar
wingerak92
Well, if you have a Sport then 265/75R16s will rub. Otherwie you will be fine
