New, stupid 2000 Dakota owner...
Old Aug 7, 2009 | 02:11 PM
Deadeye1965's Avatar
Deadeye1965
Default New, stupid 2000 Dakota owner...
needs help with transfer case I think I screwed up. Any help apprreciated.
I was trying to put it in 4 low and something gave way and now the stick on the floor is just loose, moves back and forth and no power to the wheels. Could this be a major problem or just some linkage that has broken or come loose.
I did search for an answer on here but did not see anything that was quite specifice to my problem.
Thanks!
Old Aug 7, 2009 | 02:39 PM
revdodge600sdi's Avatar
revdodge600sdi
sounds like some linkage problems..if i had to guess i would say that the transfer case is stuck in neutral..
Old Aug 7, 2009 | 02:42 PM
Deadeye1965
Kinda what I figured. any idea if it costs much to have fixed as I will not be able to do it myself.
Old Aug 7, 2009 | 08:48 PM
huseman808's Avatar
huseman808
nonsense... crawl under there and you should see where the shifter comes down through the floor. it has a small metal linkage that pops into a rubber gromit on the transfer case. if your shifter is loose you probably just popped it out of the rubber piece.
Try that and see what it gets ya.
Old Aug 7, 2009 | 10:39 PM
Deadeye1965
Thanks. I did that earlier tonight and found the linkage laying on the frame. Should not be too tough. Both gromits were almost gone rotted away. Thanks for the encouragement.
Old Aug 8, 2009 | 05:11 PM
revdodge600sdi
thats what were here for!
Old Aug 10, 2009 | 01:16 PM
Deadeye1965
Much appreciated. This forum has been a big help so far and I am sure will be in the future.
