A/C problems
Old Aug 10, 2009 | 09:59 PM
hayesapbt's Avatar
hayesapbt
Default A/C problems
Hi there. I could really use your help. I recently charged up my ac system. It is blowing warm/hot air, I am not hearing the clutch cycle, and the climate control will not chage to blow on the face. It only changes between foot and defrost. Not sure where I should start testing. The relay in the fuse box is working, there is vacuum going to the control dial. That is as far as I got.
Thank you in advance
Pete
Old Aug 11, 2009 | 01:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The service manual is located in the Stickys at the top. Check it out.
Old Aug 11, 2009 | 05:59 PM
hayesapbt's Avatar
hayesapbt
whats a sticky?
Old Aug 11, 2009 | 06:56 PM
magnethead's Avatar
magnethead
At the top of the forum (the page before list) it will say STICKY: before the title.
Old Aug 11, 2009 | 08:02 PM
varsis's Avatar
varsis
check the plug running to the black canister thingy, aka dryer. if the wires are messed up for whatever reason it can cause this. Check into it.
Old Aug 12, 2009 | 09:57 AM
hayesapbt's Avatar
hayesapbt
I have found that my AC Clutch is no engaging, even with direct power. this is gonna cost $$$$$$$$$$.
