code questions.
Old Aug 10, 2009 | 11:14 PM
reddakota34's Avatar
reddakota34
Default code questions.
1999 dodge dakota 5.2L, Okay heres the thing does anyone on here no what code p0420 means? because my trucks throwing that code.
And one more question i started my truck at my friends to drive home and when i started it my brake light and abs light came on, so i pulled out of their drive way and noticed my speedo wernt working so i drove to mc donalds and stopped and put my programmer back to stock and then started it up and the dash was clear again and the speedo worked so i started headed home again and about 8 miles down the road the speedo quit and the lights came on again and i was almost home so i stopped shut my truck off and turn the key on and off a few times to reset the computer and then i started it up and it was fine again and then drove 2 more miles to home and it was fine, but i dont no if it will do it when i drive it tomorrow does anyone no why my truck is doing this?
Old Aug 10, 2009 | 11:45 PM
magnethead's Avatar
magnethead
first, https://dodgeforum.com/forum/2nd-gen...read-this.html
It's a sticky, and usually in bold..
Second, the keydance just gives you the code, it doesn't reset the compuer. To do thet, unhok the battery and turn the key to start for 5 seconds I believe.
third, P0420 (M) 1/1 Catalytic Converter Efficiency Catalyst 1/1 efficiency below required level.
Old Aug 11, 2009 | 11:17 AM
reddakota34
so what about the speedo and those light's poping up and the spedo working then not working lol?
Old Aug 11, 2009 | 04:38 PM
reddakota34
And would it make my truck run kinda funny?
Old Aug 11, 2009 | 05:34 PM
magnethead's Avatar
magnethead
Something is failed in your ABS or proportioning valve and there is a plugged catalytic convertor.
Old Aug 11, 2009 | 10:17 PM
reddakota34
Well im byeing the sensor for the rear end tomaro i looked it up its about 40 bucks, they have one for auto trans with i have and a manual trans i wonder what the difference is. I hope it's the right sensor a few people have told me that its on the tranfer case? And also my truck just threw a nother code p0107 does anyone no what this is? and why it might have threw it?
Old Aug 11, 2009 | 10:59 PM
magnethead's Avatar
magnethead
Not to be mean but.....help yourself.
Old Aug 12, 2009 | 10:39 AM
ZANGADO's Avatar
ZANGADO
When my brake light,check engine and speedo stopped working for me I found out that it was my "speed sensor" that went bad.Check that out before it dissinigrates in your rear end.
