Why are they rubbing
Old Aug 20, 2009 | 10:24 PM
c_ryman19's Avatar
c_ryman19
Default Why are they rubbing
i have a 97 dakota 4x4 extended cab. i have 3 inch blocks in the rear and torsion bars cranked up a bit. i am running 32 inch steel radial all terrains and they rub pretty bad. why do you other guys have no problems with 32's at just a stock height?
Old Aug 21, 2009 | 12:42 AM
revdodge600sdi's Avatar
revdodge600sdi
i got an 03 quad cab with 16s and 32 inch hankooks and i got no rubbin at all.. they rubbed the first day i lefted the torsion bars up a click or two and that was it
Old Aug 21, 2009 | 01:41 AM
wingerak92's Avatar
wingerak92
Check you front bumper and such. You may need to cut the corner of the fenderwell off. Or check you mudflaps if you ahve them. you may need to screw them up against the body more.
Hey rev, do you have any clips of your exhaust? and what;s your set-up?
Old Aug 21, 2009 | 06:12 AM
c_ryman19's Avatar
c_ryman19
i have 15 inch rims with 32 and they rubbin. they are rubbin on the frame when i turn sharp
Old Aug 21, 2009 | 11:22 AM
revdodge600sdi
I just got the mbrp roll pan and exhaust kit in the other day..how ever i can not put it on yet because.. ( a few weeks ago i went off roading and backed in to a tree stump and it pushed my bumper into my bed a couple inches (cant open the tailgate)..so before i get the roll pan on i have to get it painted and the dent pulled.. but as soon as i get it all together i will have pictures!!
Old Aug 21, 2009 | 11:26 AM
revdodge600sdi
that is how my truck will look with the roll pan and exhaust
Old Aug 21, 2009 | 11:29 PM
wingerak92's Avatar
wingerak92
Haha I'm curious about the Exhaust, because I don't like my Dynomax. It sounds nice but the baffle keeps going in it making it rattle.
Old Aug 22, 2009 | 11:54 AM
RoaminGnome's Avatar
RoaminGnome
must be a backspacing issue on your rims ryman. you rockin the stock rims?
Old Aug 22, 2009 | 08:56 PM
c_ryman19's Avatar
c_ryman19
Default truck
they are not stock
Old Aug 22, 2009 | 08:57 PM
c_ryman19's Avatar
c_ryman19
Default the truck
this is what they look like
File Type: jpg
