Tire Help... yes tires
Old Sep 1, 2009 | 04:36 PM
Papa Bo's Avatar
Papa Bo
Default Tire Help... yes tires
the past week ive been searching the threads for tire sizes and have came up with some answers but i havent found anyone that did what i want to do.
im lifting my 2wd truck (yeah i know 2wd) 6inches (3" fabtech and 3" body) and i want to know what the biggest tire i can fit is? will 35"s fits?
Old Sep 2, 2009 | 12:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Maybe, Maybe not! On my 1st Gen. when I had it 2wd I lifted up 4in. 2in susp. 2in body. I was able to clear 31's up front. So 2 more inches would clear 33's up front. And 1st and 2nd Gens suspension are really close. Are you sure that fabtech makes a kit for 2wd.
Old Sep 2, 2009 | 12:09 AM
Papa Bo's Avatar
Papa Bo
yeah heres the link for the 2wd second generation fabtech kit im gonna order
http://www.ultimateautoaccessories.c.../LKS/FTS3100-3
Old Sep 2, 2009 | 01:38 PM
Papa Bo's Avatar
Papa Bo
Crazy4x4RT what all did you have to change to convert your 2wd into a 4wd?
Old Sep 2, 2009 | 03:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I basically swapped frames. I found a rollover with same engine/ body/ bed size as mine and put my cab and bed on top. Easy but time consuming. But worth it. If you wanted to read my write up here it is. https://dodgeforum.com/forum/1st-gen...x2-to-4x4.html
For yours since it is a 98 with more electronics, you may need to add in some extra wires for the transfercase and maybe add in the 4wd computer. If you really wanted check the service manual it is in the stickys in this section for all the wires and all.
Old Sep 2, 2009 | 04:05 PM
Papa Bo's Avatar
Papa Bo
would a 1st generation frame be the same as a 2nd generation?
Old Sep 2, 2009 | 04:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Not exactly the same. But if you really wanted you can make it work. You may need to do some Drilling, cutting and maybe some welding.
