Coil spacers
Hey guys I got a 99 dakota 2wd, and was wondering if these were a safe way to lift the front end just to level out the truck. And if so could it be possible to use two to get 2". And if not then what do you guys reccomend?
It depends on what kind of spacers you want to use. Like the kind you would twist into the coils are not safe. But the thick rubber spacers that you can put on 1in on top or on the bottom of the coils, or both sides for 2in. Those are god. Check http://www.summitracing.com/parts/MRG-1287/
