axles
Old Sep 17, 2009 | 05:06 PM
marc21's Avatar
marc21
Default axles
ok i plan on doing a solid axle swap and i have axle i believe just got a ? with some stuff if i take the axle out of a 1500 dodge ram would they work in my 2003 dodge dakota getting the parts is not a problem ill i got to do is have the truck off at the yard if anyone can answer that it be great thanks
Old Sep 18, 2009 | 12:24 AM
Independentfool's Avatar
Independentfool
its not a matter of 'will it work', but rather, do you have the know-how to make it work?
i would guess, however, that the ram axle is a bit wider than you want.
Old Sep 18, 2009 | 12:26 AM
magnethead's Avatar
magnethead
Ram axles are ~4" wider i think...maybe more.
Old Sep 18, 2009 | 06:03 AM
marc21's Avatar
marc21
the no how no a big deal already got people to make my custom parts and all that so and custom fenders for the tires that stick out wider then the truck
Old Sep 18, 2009 | 09:58 AM
dandragonrage's Avatar
dandragonrage
Out of curiosity... why?
Old Sep 18, 2009 | 03:43 PM
magnethead's Avatar
magnethead
what year is the 1500? I sense ABS problems in your future....unless you get lucky with the right ABS/non ABS combination...
Old Sep 19, 2009 | 07:34 AM
marc21's Avatar
marc21
the reason im doing all this is so i could get a bigger truck they dont make a suspension lift for a 2003 4x4 dakota so the solid axle swap is the next best bet ant the axle would be better to have on it im orginal looking for 3/4 ton axles or 1 tons to put underneath it
Old Sep 19, 2009 | 09:39 AM
primus454's Avatar
primus454
Things to look out for
1) Which side is the differential on, does it match your transfer case
2)Alot of dodges came with that split axleshaft set up. It's like locking hubs but instead one of the axleshafts is two separate pieces that are electronically separated.
I would recommend scouting out a late 70s F150 and get the axle out of it. It should fit neatly under a Dakota, came with a drivers side differential(like ours are), and you can get manual hubs instead of the split axle shaft crap.
Old Sep 20, 2009 | 09:00 AM
marc21's Avatar
marc21
thanks for the info will do
