Vibration problem
Old Sep 23, 2009 | 10:26 AM
00DakR/T's Avatar
00DakR/T
Default Vibration problem
I know I haven't posted anything in awhile, and I hate to come back asking questions, but this one has got me stumped.
The tires on my Dak were getting pretty skinny and I had attributed my vibration problem to tires/alignment because it was pretty much chewing the outside edges off my tires. So I get new tires, get an alignment, and I still have a bad vibration. Its the worst when you get it to 50 or 55 the first time, but at any speed above 35 it rides pretty rough. I feel like I wasted $400
Old Sep 23, 2009 | 11:15 AM
CSCustomCars's Avatar
CSCustomCars
Check the U Joints.
Old Sep 23, 2009 | 11:34 AM
00DakR/T's Avatar
00DakR/T
Thats the thing tho, the vibration is not just in the rear but in the steering wheel as well.
Old Sep 23, 2009 | 12:29 PM
bpark8824's Avatar
bpark8824
They were balanced properly right?
Old Sep 23, 2009 | 01:16 PM
00DakR/T's Avatar
00DakR/T
I would assume so. I had this problem before I got the new tires put on and it definately has new weights on it now. For $22 a tire to mount and balance they better be right lol
Old Sep 23, 2009 | 01:26 PM
bpark8824's Avatar
bpark8824
Hah yeah I know what you mean. But it sounds more like your universals if it did it before and again after new tires were mounted and balanced.
Old Sep 23, 2009 | 02:50 PM
reddakota34's Avatar
reddakota34
Bad unaversal
Old Sep 23, 2009 | 03:50 PM
00DakR/T's Avatar
00DakR/T
I guess this is just one of those situations where I am different from everybody else. I can tackle an electrical problem like nobody's business but suspension and driveline...I'm usually totally lost. I'll give the U-joints a shot because this crap is driving me crazy
Old Sep 23, 2009 | 06:43 PM
CSCustomCars
The u-joints are bad in my suburban and the whole truck has this annoying vibration. More pronounced in the seat but it's still in the steering wheel. With u-joints the entire truck will vibrate, not as if it were just a bad wheel balance. Do you know how to check the u-joints?
Old Sep 24, 2009 | 02:42 PM
sigraph's Avatar
sigraph
Could be an out of round tire. A u-joint vibration compared to a wheel/tire problem would be a much faster vibration. Could also be a bent drive shaft from an improperly placed lift arm at the garage - I've done it. Does the vibration seem to be the same as tire rotation or does it seem a lot faster? If your tires are new, you can drive down a gravel road and you'd probably pick up a rock in one of your tires. When you pull back onto a paved roadway you might be able to hear the rock hitting the road and get a good idea around 35 mph whether the vibration compares to the sound of the rock or if it's a lot faster. Sounds stupid, but I just got a new pair of Michelins and they usually sling a rock or 2 after driving in gravel. If it's faster it's probably a drive line component since they spin much faster than the tires do.
