max tire size with 2in leveling kit
Old Sep 25, 2009 | 12:15 AM
urk2010's Avatar
urk2010
Default max tire size with 2in leveling kit
Hi I want to know how big of tires I can fit on my 2001 4x4 dak with a 2in leveling kit with no rubbing. I want to make my truck look a bit more beefy. I'm thinking about Cooper STT and BFG all terrain or mud terrains...What tires do u think will look the best?
Old Sep 25, 2009 | 01:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
According to this chart a 2in can get you 31's. Maybe 33's if you cut the fender corners or so.
http://www.4wheeloffroad.com/techart...ide/index.html
Old Sep 25, 2009 | 08:15 PM
bpark8824's Avatar
bpark8824
The Cooper SST's look sweet... 31's fit stock, so 33's should be close, might need some trimming.
Old Sep 26, 2009 | 04:03 PM
fourpointseven's Avatar
fourpointseven
you will need to break out the cuttin disc's if your going with 33s. i got a 3inch body lift and im still rubbing some with the 33 tires. had to cut the front bumper and some of the plastics inside.
you dont need a levling kit, just raise the TB's and get a 3"body with 33's. 31s will fit better then 33s if your deciding to go 2" higher
