Airbag Light
Old Mar 2, 2010 | 08:01 PM
tilley2491's Avatar
tilley2491
Default found it
its the clockspring for those who have the light go on while turning left or right more than 60 degrees, or if your horn or other steering wheel electronics dont work.
Old Mar 8, 2010 | 11:23 PM
250KDakota97's Avatar
250KDakota97
mines got the same issue, and i've heard of a few cases where it randomly went off as the light was on, but its very rare, so that shouldnt be an issue at least
Old Apr 26, 2010 | 01:11 AM
Jamminific's Avatar
Jamminific
Hey all. I have a '02 4.7 Dakota SLT. the air bag light is on and off intermittently, mostly on recently. My cruise, horn and radio are also out of commision. Is this all related to the clockspring?
Old Dec 2, 2011 | 07:19 PM
joemama1967's Avatar
joemama1967
The problem I had with my airbag light being on was the passenger override switch. The bulb was burned out in the switch. I soldered a new 12 blub in it and now the airbag light is off
So, if you have a passenger override and turn it to "off" and there is NO light at the switch, that might be the problem.
Old Nov 25, 2016 | 05:27 PM
Bigblock066's Avatar
Bigblock066
Replaced clockspring in my 01dakota now it won't let me reset airbag light, scan tool says there's an open Squibb!?! So now what? Any help please
Old Nov 29, 2016 | 02:27 PM
00DakDan's Avatar
00DakDan
Section Moderator
The squib itself is in the airbag. Double check all connections.
Old Nov 30, 2016 | 08:35 AM
Bigblock066
I didn't replace old wire from clockspring w/new wire from new clockspring could this be why I have the Squibb?
Old Nov 30, 2016 | 08:54 PM
00DakDan's Avatar
00DakDan
Section Moderator
Not sure what you're saying. You need to make sure all the connectors on the clockspring are fully seated, you should have 3 connectors. The yellow one is for the airbags.
Old Dec 1, 2016 | 09:03 AM
Bigblock066
thank you I will check it out this morning & respond back later.
Old Dec 6, 2016 | 10:30 PM
Bigblock066
checked all connections , scanner still says driver1 open squibb
